[10553] Fixed Normal vectors scaling problem and French Patch update / JimmyMarco3D
[不具合報告] 返信
Hi,
In my previous message, I haven't explained clearly the Fixed normal vectors scaling problem, so this screenshots show what happened when the Scale option is used in Local axis command :
https://i.goopics.net/0r6hgx.jpg
https://i.goopics.net/h2d8z8.jpg
https://i.goopics.net/640oin.jpg
The fixed vectors are x10 bigger when the Scale is setted x10.
Last update of the French patch.
https://www.aht.li/3959385/PatchFrancaisMetasequoia490f.zip
Bests regards.
JimmyMarco3D
2026-02-16 20:29
[10555] Re: Fixed Normal vectors scaling problem and French Patch update / 管理者
Was this model created within Metasequoia, or did you import external data?
2026-02-17 17:33
[10556] Re: Fixed Normal vectors scaling problem and French Patch update / JimmyMarco3D
Hi
All my models are created with Metasequoia since 2005, and the the french patch too, version LE R2.1 for the first one, if my memory is good.
I have just tried another time to be sure :
Create a basic primitive, apply fixed normal, scaling x10 with Scale in Local axis, and the result is the same :
https://i.goopics.net/fjeyto.jpg
https://i.goopics.net/tboxal.jpg
The fixed vectors are x10, not the non fixed vectors.
I hope this "little bug" can be fixed.
Bests regards.
JimmyMarco3D
2026-02-17 18:26
[10557] Re: Fixed Normal vectors scaling problem and French Patch update / JimmyMarco3D
https://i.goopics.net/4ipqbw.jpg
https://i.goopics.net/ynkdq6.jpg
I can do that all day long... I like Metasequoia.
2026-02-17 18:45
[10558] Re: Fixed Normal vectors scaling problem and French Patch update / 管理者
I've noticed that [Local] commands cause strange normals, so this problem will be fixed in the next release.
2026-02-18 16:34
[10563] Re: Fixed Normal vectors scaling problem and French Patch update / gery
>Hi,
2026-02-18 18:40
