[9669] i cant find Join closed vertices Code / material poperty parameters
対応済み [要望,help! ] 返信
Join Closed Vertices:
Any vertices in the current object, which are close to each other, are joined together. (A dialog box appears, which you use to specify how close together the vertices need to be.)
import MQSystem
doc = MQSystem.getDocument()
objnum = doc.numObject
for oi in range(0, objnum):
    obj = doc.object[oi]
    if obj is None:
        continue
    if obj.name == "obj":
        obj.select = 1
        break
2023-02-12 10:16
[9673] Re: i cant find Join closed vertices Code / material poperty parameters
>MQObject.optimizeVertex() joins vertices within a specified distance. Is this function what you are looking for?
yes thnx!
2023-02-13 13:35
