[9662] Script editor / material poperty parameters
対応済み [質問,Who are you?] 返信
how to change material poperty- parameters  when selecting model then it changes all the materials selected object only
for obj in ObjectEnum() do
  mat = MaterialGet(obj)
  MaterialSetAlpha mat, 1.00
  MaterialSetDiffuse mat, 0.80
  MaterialSetEmission mat, 0.75
  MaterialSetSpecular mat, 0.00
  MaterialSetPower mat, 5.00
  MaterialSetAmbient mat, 0.00
  MaterialSetReflection mat, 0.00
  MaterialSetRefraction mat, 1.00
end
Error code
Failed to execute a script in line 1.
Invalid syntax. (invalid syntax)
for obj in ObjectEnum() <<<do
2023-02-09 05:13
途中の4件のメッセージを表示
[9667] Re: Script editor / 管理者
What you are asking for is already in the response I have already given, but I will state the same sentence again.
The 'Help' menu in the script editor contains descriptions of classes, functions, and properties.
Please check within the help to see what properties MQObject, MQMaterial, etc. have, and what types they are.
2023-02-10 15:49
