Metasequoia has a parent-child hierarchy function rather than grouping objects.
Pressing the '<' or '>' button in the object panel will make the object above it in the list the parent, or return it to the same hierarchy.
2025-10-25 10:35
Yes but I need that a series of objects then work as one for instance when I move or scale them. Is it the same using hierarchies ?
2025-10-25 16:54
