[10434] How make the boolean object / Giovanni Chiozza
[Question] Response
I'm just trying to use MSQ using free version.
I'm wondering where is the menu to subtract 2 objets with boolean . I see the manual but I don't see the menu where to use it ? Is it hidden or not available on free version ?
Thanks
2025-10-07 17:37
[10435] Re: How make the boolean object / Administrator
Please call the [Object > Boolean] menu.
And, the Help in the [Help > Index] has a search function that allows you to find functions by keyword.
2025-10-07 21:56
[10436] Re: How make the boolean object / Giovanni Chiozza
I installed MSQ from this file Metaseq490d_x64_Installer.exe
Do I need to install something more ?
Under Object menu I got only
Create
Freeze
Reduce polygons
Align faces
Unify faces
Do I need to install something else ?
The short key would be Shift S but nothing happens
Do I need to reinstall all from scratch ?
Thanks
2025-10-07 23:17
[10437] Re: How make the boolean object / Administrator
As the instructions are displayed at startup (unless you have turned it off), the [Beginner] mode hides modeling functions beyond the bare minimum.
Switch to the [Modeling] mode from the top left of the screen.
2025-10-08 09:57
[10438] Re: How make the boolean object / Giovanni Chiozza
OK Thanks !!! Boom ! That was it
2025-10-08 16:20
